I know you hate bose but...
Username: Damians
Post Number: 9
they are still the best looking speaker system I've ever seen. I kind of keen on design. I also know they might sound a bit clumsy or trashy but...may I add any other spekear to solve out this issue? May be if I add 2 bookshelf speakers -at the expense of costs- I can help it work better, still having good design and finally build up a 7.1 system.
What do you think about this?
Thanks!
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 277
If you are more concerned with look than function it is very likely that you will be very happy using Bose. They are highly regarded in some circles and some wouldn't trade them for anything. Speaking strictly for myself I always try to steer my customers away from Bose because I can get equal or better sound for a lot less money but if that is what they want (even if it is just to impress the neighbors) that is what we go with and they sound just fine.
Username: Mr_home_theater
Margaritaville, Florida USA
Post Number: 19
jim have you ever heard of episode speakers some one on craigs list had them for sale i could not find any reviews. just thier web site. but i am thinking they might be a scam. any advice?
Username: Jrbay
Post Number: 280
Not to steal this thread or anything but no, I haven't heard of Episode. If they are a scam someone has certainly gone to a lot of trouble on their website. It looks pretty good.
Post Number: 20
thanks i forgot to start a new thread
Username: Ceporter7
McKeeksport, Cporter USA
can bose accoutimass speakers be used iwth a different powered subwoofer without being harmed? Should they only be used with the accoustimass module.
Username: Jrbay
Post Number: 1041
Harmed or sound good?
Probably not on both counts!
If I were you though I would make sure to leave a pig tail on the wire before I cut it (a substantial length still left with the connector) so when you splice it back together you have something to work with.
Need to Register?
Forgot Password?
Enable HTML code in message
