Need surround hooked up
Username: Turban02
i just bought a new LG Scarlet and i can't hook my Panasonic home theater SA-PT750 surround sound to the tv. the outputs i have from the tv is digital coxial and digital opitical. now is there some product out there that goes from a L and R rca audio into a single digital or optic cable? by the way surround sound receiver doesn't have the digital coxial or opitic input or output. what can i do to get my surround sound going for my tv and ps3?
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 511
What are you using as a TV tuner. A cable box by chance?
Username: Turban02
yes i have DVR digital cable box through my service provider. now that has an opitical cable should i run that to my box and have the rca cables run to the surround sound?
Username: Jrbay
Post Number: 512
How is it hooked up right now? Running audio out from the cable box to your Panasonic will solve your problem.
Username: Turban02
okay i didnt think of that at the time. thanks a lot
Need to Register?
Forgot Password?
Enable HTML code in message
