Klipsch ProMedia 5.1...not sounding good.
Username: Bakakun
Yeah, I bought these speakers 'bout 2 years ago and honestly they don't sound as good as the 4.1 my brother have. Is it because of my soundcard (SoundBlaster Audigy Z Platinum)? Or something else. The sound itself is good, but I can't really power the subwoofer past 45 volume (creative media) without hearing alot of distortion. Any input will be appreciated. Thanks!!!
Username: Project6
Post Number: 8437
You need a better subwoofer.
Username: Heymaynard
Same setup at home but I have the 5.1 with Klipsch Sub. Is the a possibility that the filter is not set right on the sound card and there are to many highs going to the Sub
Username: Project6
Post Number: 8558
No, the problem is, that there is not a lot of thought put in on computer speakers. It is not like a regular home theater set-up. Don't expect too much of PC speakers or your sound card. the best you can do is go to the advance settings of your soundcard and play with the equalizer.
Need to Register?
Forgot Password?
Enable HTML code in message
