HTCP vs reciever for HDTV
Username: Boo71886
Post Number: 13
I am currently building a entire home theater system for my new apartment I'm moving into in August. For my entertainment system, this is the components
TV
Samsung HL-R87W/88W
TV Pedastal
TR85 Pedestal DLP Stand
Home Theater System
JBL Northbridge Series (5.1)
EC35-center
E100- Front sides
E100- Back sides
E250P- subwoofer
Universal Remote- Logitech Harmony 880
A/V Reciever- JVC RX-D702B
That TV supports HDTV, so i figured i should get a reciever that would allow me to do that also, but then I saw a really nice HTCP build on Extreme Tech.com seen here http://www.extremetech.com/article2/0,1697,1910025,00.asp
When I saw that I figured wow, I can hook that up and have all my movies and music on there, and if I get the Silverstone LaScala LC18 case there would be no need for a keyboard and mouse. My question is, does it make more since to go with the HTCP or the JVC reciever I listed?
Username: Project6
Post Number: 7780
If that is what you want to happen, of course it makes more sense. it really depends on the end consumer. Are you going to be using the computer for other things or just for the Home Theater?
Username: Project6
Post Number: 7781
Now you realize that the Home Theater PC is not designed to run your Home Theater Speaker systems now don't you? You will still need an amplifier to drive your speakers.
Username: Boo71886
Post Number: 18
no the comp will only b used for the home theater, i was looking at xbox mods how ever and was considering just buying one already modded, do you think its worth it?
Username: Project6
Post Number: 7793
Do you mean that you are going to use a modified xbox as a DVD player/game system? If that is the case, I personally don't like using a game system as my DVD player, I have a dedicated DVD player for that purpose. The xbox is a great game system, and it should stay as such. But if you are a gamer, it is definitely worth it. If not, keep the xbox separate.
My question is, how are you going to get the sound to your Northridge series speakers?
Username: Boo71886
Post Number: 19
Berny- to answer the first question, yes i am a gamer and yes i would use it for gaming, media center, and dvd watching. You can buy a modified xbox for way cheaper then a HTCP, plus the modified xboxs have XBOX Media Center which is like windows media center. I can get the same amount of space as on a computer, and play games, music, etc on the xbox. I think its worth it to just buy that instead of spending like 2,500.00 on an HTCP. What do you think?
Second question- to hook up those speakers I will be useing my JVC RX-D702B reciever. I changed the remote to a PHILIPS RC9800I, and added a BELKIN AP41300 to regulate voltage and for surge protection, are those good parts? I read up on them especially that remote and it has ALOT of nice features.
Username: Project6
Post Number: 7807
Any reliability issues on a modded Xbox? That would be my first concern. But for the purpose you want, I think it is worth it over a whole new PC.
Username: Boo71886
Post Number: 20
No, and i wont be modding it myself, Im goin to purchase a premodded xbox. This is the xbox
http://www.modchipworld.com/product_info.php?products_id=226
its 529.00 dollers. I figured since i can copy the games to the hard drive as well as movies n roms with evoX(downloading now took for ever to find it). check it out n let me know wat u think
Username: Project6
Post Number: 7810
Very niiiice! Seems like a good machine. Just make sure it has a good warranty.
Username: Boo71886
Post Number: 21
would u be willing 2 go to my other threads n answer my questions Berny? u seem to know alot
Username: Project6
Post Number: 7815
What other threads???
Dude, my only knowledge is through experience. I am willing to help, but only in areas I can tackle. :-)
Need to Register?
Forgot Password?
Enable HTML code in message
