Need a sub, any thoughts?
Username: Dphil
Hello. I am setting up my first home theater and have been reading this forum for a few weeks now. I need a sub and am not sure what I should be looking for. I've decided on the Klipsch Quintet IIIs, and the Yamaha RX V557 receiver. I don't would like to spend around 200 on the sub, is this reasonable? My room is 15 x 12.
thanks
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 98
You have a medium size room. A $200 sub is not going to cut it in any size room. Paradigm sub PDR-10 is about $400 anything less is a waste of money. A ten inch driver and a 200 watt amp should do.
Username: Chitown
Post Number: 877
Take a look at HSU
Username: Praetorian
Post Number: 119
Or Velodyne.
Username: Dphil
thanks for your time, guys. I'll look into these.
Username: Angelo
New york
Post Number: 15
how is the klipsch Quintet IIIs? I was going to buy them but decided to go with orb audio mod2 instead
Username: Davephil
Actually I opted for the IIs. I bought a HSU 10 inch sub and was going over budget. Have not set up the system yet as I am waiting on the receiver.
Username: Chitown
Post Number: 890
Just make sure you don't end up crawling to the ground laughin with joy after you hook it up and hear its sound. You will look silly. I know I did.
Username: Davephil
actually I plan on doing that tonight. The receiver was delivered today.
