Help with cables pls
Username: Vanislejc
Victoria, Bc Canada
Hi there, I am in the middle of buying a new tv looking to spend around 1000cdn...Looking at a 34 inch widescreen tube toshiba, anyone have any thoughts?? My real concern is with the cables...I wont be hooking up hd right away. I will be hooking up a dvd player and vcr to my pioneer vsx-1015tx. How should i go about it?? i am on a budget mind you.. i was thinking component video from dvd to tv or s video. and coaxial from dvd to amp? and rcas from vcr to tv...i also want to hook my computer up to my amp what are the best cables for doing that it is about 30 feet away.. any information and input would really help me out thanks
Username: Project6
Post Number: 7049
A little reading is in order.
Learn all you can.
http://www.audioholics.com/techtips/audioprinciples/cables.htm
Username: Neilg
Hi,
Recently bought a 5.1 Bush Surround System. I have connected all the speakers upto the Sub Woofer, and all the input cables also into the subwoofer that need to connect upto the TV, DVD etc. I have 3 white cables and three red cables joint together - ie 1 red and white grouped (ie 3 sets of 2). Can i connect one set to my tv, one to my dvd and 1 to my Hi-Fi or not. I do not know anything about how to connect the system up.
SOMEONE PLEASE HELP ME !!!!!!
Username: Project6
Post Number: 7067
I know that you are new but, next time start your own thread, do not hijack another's thread because they get notifications on their posts.
Go here..
http://www.ce.org/connections_application/
