Placement
Username: Zany
Just wanted to get some feedback on In-Wall speaker placement.
Any suggestions would be appreciated.
Username: Westcott
League City, Texas
Post Number: 82
Place them about two to three feet from the back wall and 3 or 4 feet from the side walls.
The last thing you want to do is place them in the wall.
Username: John_s
Columbus, Ohio US
Post Number: 804
ricky, I'm assuming you are speaking of in-wall speakers in a 5 point surround system. One of the bug disadvantages of these is that once in, they're in....unless you want to cut multiple holes until you're satisfied, and only a crazy man would do that.
If I had this opportunity, I would install the front 3 on the same horizontal plane as possible, and as close to the screen as possible. In normal rooms there has to be some compromise here, but do the best you can along those lines.
The rears would be slightly to the rear of the listening position and up maybe 2 or 3 feet from ear level.
