No Big Problem
Username: James_millard
Post Number: 47
on most other forums
the smiley face not coming out complete.
Username: Cheap_trick
Post Number: 167
problem fixed. Thank you.
Username: Finish22
Post Number: 65
Two months ago the smileys started to come out incomplete,
Now they down even come out at all... Upload
Username: Finish22
Post Number: 90
again the smileys are coming out incomplete
and clickers are off-centered :
Moderator
Username: Admin
Post Number: 7438
What web browser are you using?
Username: Finish22
Post Number: 91
Mozilla Firefox
Moderator
Username: Admin
Post Number: 7439
Do the know the version number? I will test with the latest version of Mozilla Firefox for Windows and get back to you.
Username: Plymouth
Post Number: 13538
Work fine for me with XP, Win 2000 and Win98 on Firefox and Explorer!
Username: Finish22
Post Number: 92
latest version. ( version 3.6.2 )
this is only happening on the TEST PAGE ("new forum design"),
the Forums are working OK
Username: Pish_posh
A lot harder to see
Moderator
Username: Admin
Post Number: 7441
I just tested the new design on Firefox 3.6.2 on Windows Vista, and I can't replicate the problem you are showing.
Username: Finish22
Post Number: 93
sorry. the problem was on my side.
I tweaked the zoom settings and now its working fine.
Moderator
Username: Admin
Post Number: 7446
Glad to see it's working for you.
Username: Doreenakadj
Post Number: 4283
sorry to be a pest but the triangles don't work
Post Number: 4284
see no triangles... I clicked on every one of the smileys
Username: Plymouth
Post Number: 13567
Upload Upload
Post Number: 4288
I am using IE 8 on windows 7
Post Number: 4289
sorry I meant NOTHING shows up
Username: Plymouth
Post Number: 13569
Doreen
Emoticon are not available!
I just copied the gif and posted it like a picture with "Upload Image" until Admin re-actived it!
Post Number: 4290
k thanks
Moderator
Username: Admin
Post Number: 7447
Another good catch. The arrows were left out. Adding that to the todo list.
Username: Plymouth
Post Number: 13573
Admin
The Edit button is not available also on right upper side of the window on New Forum Design!
Thanks!
Moderator
Username: Admin
Post Number: 7449
I believe most people are seeing the "edit" icon to the right of each post. Plymouth, which browser are you using?
Diamond Member
Www.stainles... .ecrater.com
Post Number: 22569
Edit post button appears for me using Google Chrome.
Post Number: 4294
I see it using IE8 but like I wrote in the other thread, when using the "edit" all the text is on the same line. you have to scroll over to the right to read it all. it's annoying when fixing your post
Username: Plymouth
Post Number: 13577
Admin
Usualy for eCoustics, I use a old computer 1.7 meg with Win 98 and Firefox 2.0.0.17 to prevent virus then the speed of using but I will use another soon with XP!
I tested with Explorer then it work fine!
The Emoticone then Edit Button do not work with this Firefox Version!
Moderator
Username: Admin
Post Number: 7453
I just made a change that might make Firefox 2 show the icons. Let me know.
Username: Plymouth
Post Number: 13583
Admin
No change, I can't see the edit button as well for the Emoticon
Username: Plymouth
Post Number: 13584
Admin
Note that the Edit button work on old forum but the Emoticon still not work.
Moderator
Username: Admin
Post Number: 7454
I am still testing things in this section. If the icons appear as before here, please let me know.
Username: Plymouth
Post Number: 13586
Ok all work fine now!
Username: Plymouth
Post Number: 13587
You see the Edit button in not in the center of the line!
Moderator
Username: Admin
Post Number: 7455
Great news! Thanks for getting back to me so quick.
Username: Plymouth
Post Number: 13588
I noticed also that "My Account" is not available on the top of page, maybe you know it!
Moderator
Username: Admin
Post Number: 7456
I believe you mean the link "My Account"? That was moved to upper right list of links, labeled "Your forum account".
Moderator
Username: Admin
Post Number: 7457
Also, I do see the "edit" icon is not aligned correctly in your browser. I just tried another fix for Firefox 2. Let me know if it's any better.
Username: Plymouth
Post Number: 13589
Ok I can see it in the upper right window!
Username: Plymouth
Post Number: 13590
Here is the latest page copy
You can see that the Edit button is misaligned again
Post Number: 4305
LOL Admin what thread would you like me to posts all my findings in ? this one or the other one... it will save you the trouble of boncing back and forth from this thread ot the one I keep posting in.
Post Number: 4306
oh and BTW I have a suggestion to make.....
Username: Finish22
Post Number: 96
Doreen posted >> LOL Admin what thread would you like me to posts all my findings in ?
why dont we leave this thread for all the minor tweaks and use the other thread
only for the new design overall look?
BTW. Doreen is so full of Upload Uploadexcellent observations and ideas
she should be appointed something like the site enhancement consultant.
Moderator
Username: Admin
Post Number: 7461
I do see the extra space above the Country. Adding to list to fix.
Moderator
Username: Admin
Post Number: 7477
The extra spacing should now be fixed going forward.
Need to Register?
Forgot Password?
Enable HTML code in message
