New search
Username: Matt12490
California USA
Post Number: 2614
I may be mistaken here but everytime I try to use the search feature it brings me to the not so handy dandy "try out the new search engine" which just uses google to find random threads that are nothing what I'm looking for. It couldnt even find a thread with 'rearrangeyamind' in the title, but instead found other threads I've posted in. Is there a way to search through my old posts or search the names of threads like the old search (which also had its problems)? I really need to find something important.
If there is another search engine and I missed it let me know. Otherwise, lets get something new!
Moderator
Username: Admin
Post Number: 6632
To search specific keywords in the title of threads, add "allintitle:" before your search term.
In your example, search for "allintitle:rearrangeyamind" (quotes removed)
However, the above search still did not find any results.
Need to Register?
Forgot Password?
Enable HTML code in message
