Sloooow page load
A pic is worth 1000 posts!!
Post Number: 10782
The past few weeks I have been having a delay in page loading. At first I thought it was my PC but I just bought a brand new one and still have the same problem. No joke it takes a good 15-20 seconds to navigate from page to page. Very annoying. There seems to be some sort of text highlighting program attaching popups to key words. Problem is I can't even navigate through the page until the page fully loads, about 15-20 seconds. Also I have to be careful what I hover my pointer over cause it prompts another popup. This feature of Ecoustics makes it very aggravating to browse the forum and post. I haven't heard anyone else mention this problem so I'm inclined to ask if this is indeed part of E or something on my end. Thanks.
Username: Satscanners
Beaversbush, Sportsmans P... Great White ...
Post Number: 19
I get the same thing Paul.
Post Number: 10786
Yeah I figured it was ad $$ after I got no response from the admin. Business as usual....
Username: Tapeman
New York City in-HD, NY
Post Number: 1759
I agree
very aggravating
Post Number: 10790
Username: Stryvn
Post Number: 535
Here's the fix (to get rid of the green underscored popup text) for IE, Paul:
Tools
Internet Options
Security Tab
Highlight "Restricted Sites"
Click "Sites" button
add this line.... *.us.intellitxt.com
That will get rid of the popup problem.
Sorry, I can't help with the page load time.
Take it easy.
Post Number: 10812
Thanks stryvn. It works.
Username: Nd4spd18
Northwest PA
Post Number: 4886
Bwhahahaha
Us > ad companies
Post Number: 11953
Lol. Yeah it worked. But everytime another ad buys space I have to add it to the list. Trouble now is it scrolls so fast I can't catch the link. They're always one step ahead. Now I'm back to hearing several clicks each time I navigate, then the long azz pause. Suk.
Username: Nd4spd18
Northwest PA
Post Number: 4982
It worked great for me...... I just did what stryvn said and no more green highlights, no more delay in the page loads :-)
Username: Adddisorder
Palm Beach, Florida
Post Number: 5680
thanks.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 990
Valuable info, muchos gracias.
Username: Project6
Post Number: 14122
I don't get this pop ups from ecoustics.
Post Number: 12125
What browser do you use, IE, Firefox, opera...????
Username: Project6
Post Number: 14123
Firefox and it is set to block a lot of scripts.
Username: Naledge503
Http://www.LowDownForu...Zac Davis 4 ...
Post Number: 2548
I dont get it with FF but with Opera I do, and I dont know how to fix it :-(
Username: Lklives
Post Number: 13895
See below for comments. You ARE seeing the problem. Odd words that show up in green with a double underline. Not necessarily the same for each user. And adaware won't clear it. Neither will spybot S&D or SpywareBlaster. Some found that Windows Washer does clean it and I agree. But it's a patch up. It doesn't KEEP the buggers away
This program is a pay for ad hit program. So it starts to gather stats about your website, including things like Alexa Rank, page views per day, unique users per day, repurchase rate, and some estimated click through data. This information is available not only to potential advertising customers, but anyone who wants to look, so this program is best suited for websites you are comfortable with revealing some data about. Something to be aware of is, if you list more than one site in your AdBrite account, anyone who checks the stats will see the connection between the two websites.
if you have got bitten your PC now has a cookie that needs to be removed. It is a combination. The site has to be infected and your PC must have the cookie that activates it. If you don't have the cookie on your PC you will not see the ads.
And the problem seems to be that even if you find and delete that cookie (Which Windows Washer does seem to do) the damned thing gets re-set on your computer if you end up in the right threads/sections/posts.
The FIX...
download a adblock program ... Its a small program that runs in the background ....
I would assume any adblocker program would do the samething...
SO watch out, Ecoustics is doing this to YOU!!!!...They are fully aware and performing this to all of us here..
Moderator
Username: Admin
Post Number: 3208
The double underlined green mouse-over links are called IntelliTXT ads and are dynamically placed into pages from Vibrant Media.
http://en.wikipedia.org/wiki/IntelliTXT
http://www.vibrantmedia.com/privacy.asp
Post Number: 2559
How to fix for opera.
Tools/Advanced/Blocked Content..
Then add this:
http://*.us.intellitxt.com/*
Need to Register?
Forgot Password?
Enable HTML code in message
