Focus Enhancements CenterStage CS-HD Scaler
Diamond Member
Username: Ecoustics
Fairfax, VA USA
Post Number: 176
This review has moved to the link below:
https://www.ecoustics.com/reviews/focus-enhancements-centerstage-cs-hd-scaler/
murray
i have an hitachi 60v500 lcd 60" and a denon 2200 dvd player no cable or sattalite im a little confused on what this video scaler is and if its something that will improve my picture it looks to me like it just turns it into progressive scan and i already have that
I'm considering getting a Sharp "Aquos" series 45" LCD flat panel HDTV/monitor. It's capable of very hi-res displays, up to 1080p. I'm sure DVDs and HDTV will look fine, but I'm concerned about regular non-HD TV. Will this scaler make a significant improvement? I don't expect it to be as good as HD, but regular TV seen on a large monitor without scaling or up-converting is ususally pretty mediocre!
Username: Fraser55555
Farmington, GA USA
I had hoped for a professional response to my, quite simple problem, but maybe you guys know anyway.
My Echostar receiver formats satellite pictures (including hi-def) just fine.
When I plug CMP video from my DVD into the same display, I get short fat people. Please recommend an appropriate scaler---nothing too fancy! Thanks -----Donald Kerr
Need to Register?
Forgot Password?
Enable HTML code in message
