Pansat 2700
Username: Tommy_h
Hi all I am new to the FTA world it's my first time trying this out. A friend of mine gave me his old Pansat 2700 receiver and told me to get the necessary RQ-SSSP file.
I download the file. but the msvcr71.d11 is missing.
My questions are:
Where to download the missing file and where to put it once i get get?
Does anyone have step by step instructions? The copy i have is very vague.
Can you please tell me what other equipment i might need, such as LMB, the right dish and satellites to get?
Username: Mrgreg
Post Number: 1364
Try here: or
Username: Mrgreg
Post Number: 1365
Or here:
Username: Tommy_h
thanks Mrgreg , I will look into it ,but if anyone else can give me some advice that would be greatly appreciated too.
Username: Tommy_h
What private servers can you use for the pansat 2700?
Greg or anyone else here please help me? I haven't got the foggiest idea where to start here.
Username: Chaff
Post Number: 943
http://www.google.com/search?q=What+private+servers+can+you+use+for+the+pansat+2 700&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Diamond Member
Username: Nydas
Post Number: 22536
tommyhesaw New member
Username: Tommy_h
msvcr71.dll is a module containing standard C library functions such as printf, memcpy, and cos. It is a part of the Microsoft C Runtime Library.
It is required for the essential running of the Microsoft libraries so it should not be removed.
Sometime when you install a new software the rigistry gets damaged and you get this messages. sometimes A vurus destroys or remove this files.
A detailed reading about it is at
http://pcsupport.about.com/od/findbyerrormessage/a/msvcr71-dll-not-found-missing -error.htm
This URL cautions you NOT to download the DLL file which is easy to obtain from many sources, such as :
http://www.dll-files.com/dllindex/dll-files.shtml?msvcr71
I have therefore, a duty to caution you about a direct download and installation.
It's home is your windows folder and System32 subfolder.
However details of installation can vary. More details here.
http://www.addictivetips.com/windows-tips/fix-msvcp71-dll-and-msvcr71-dll-missin g-error-in-windows-7/
Username: Tommy_h
the rar file i download said it was included , but it wasn't in there
Copy and pasted from the site
These are the necessary RQ-SSSP files.
Including "msvcr71.d11".
Thanks for the links and how to use the DLL file Nydas
I will look at the links later. I have to work early and will let you know how things went later tomorrow.
Username: Tommy_h
Post Number: 12
I just went to a different site that my friend told me about and downloaded a newer RQ-SSSP rar file . It came with all i need. Everything seems to be working now, but thanks for trying to help
Username: Eldonperrito
Huntington Beach, California Usa
Post Number: 123
You are way outdate with your pansat get an atary system it will be cheaper and more fun.
Username: Tommy_h
Post Number: 24
Peritto, from what i've read you might be right about my Pansat. .
Username: Lion_cing
Post Number: 55
WHAT? Pansat 2700 still works. I have not used it for past 2 years or more. Can someone please send me a link to where I can read about updating this device. your help will be appreciated.
Username: Krishn
Post Number: 1715
Bob:
Need a few things to make it work.
(i) High speed internet connection
(ii) Connection to your router by an ethernet cable or powerline adapter
(iii) (a) X-FTA dongle
or
(b) PC or desktop always connected to pansat - very likely PC or desktop does not have DB9 serial port, in that case you need an USB to DB9 adapter
(iv) subscription to a private server - NFPS or IKS Rocket or other
Username: Krishn
Post Number: 1716
Bob:
Read this thread
Username: Lion_cing
Post Number: 56
Subash Thank you. I have the first 3
let me read your link and get back to you.
Thank you again
Username: Lion_cing
Post Number: 57
Hi subash. Thanks Yaar, You the only one willing to help. Well I went through the Pansat info link and few others, but could NOT find any step by step instruction about how to upgrade my Pansat 2700A.
Can you or anyone please send me a link
Thanks.
Username: Krishn
Post Number: 1718
Bob:
You may not need item (ii) for X-FTA, however not sure how it works with wireless.
see this link:
see here
Username: Kent_island
Post Number: 43
Hey, Subash......do you ever sleep?
Username: Mememememe
Post Number: 60
Post Number: 281
Post Number: 461
Need to Register?
Forgot Password?
Enable HTML code in message
