Viewsat xtreme do i need a dongle or something to make it work ???
Username: Bjcrisp6478
Post Number: 354
i saw on another fta sit there is a fix for the xtreme but i have to pay to get it but before i pay i want to know what type of dongle,ika or weather thing i need for it to work? any help would be grateful.
Username: Xerxes
Post Number: 59
Re: Viewsat Extreme
They say......http://dsspros.com/forum/viewsat-help-files-discussions/79041-viewsat-extreme-pr int.html
No dongle needed, cable runs from pc to stb and stay's connected while in use.
Post Number: 356
what is stb? this is all new to me
Diamond Member
Username: Nydas
Post Number: 23273
STB stands for Set-Top-Box.
Same as receiver.
The URLs given has posts over a month old.
I don't think you would get too many channels without a dongle, if that.
Username: Creek
Smithtown, New York
Post Number: 570
Where do I buy this dongle for my viewsat extreme?
Thanks.
Diamond Member
Username: Nydas
Post Number: 23275
You can buy the Viewsat Dongle at these sites, but whether or not it will work, I have no idea.
You take 100% risk.
http://viewsatprivateserver.co/viewsat-dongle-iks/
Username: Kent_island50
Post Number: 150
Friend......don't waste your time and money
The two sites that nydas has posted above do not list
Viewsat Extreme. Why?......because there is no dongle support for that unit.Viewsat Extreme can only
be used for true FTA..... sorry friend.
Username: Mrgreg
Post Number: 1492
You better go do some reading Fish because that is a false accusation!
Post Number: 152
OK.....Mr. Greg If I'm wrong it won't be the first time and I'm sure it won't be the last.
Now show the Link where there is dongle
support for Viewsat Extreme
Username: Mrgreg
Post Number: 1493
The X-FTA Dongle-Router works with it.Also the RQ-SSSP Client with your computer works too.Here is your quote: Extreme can only
be used for true FTA..... sorry friend. Here is a link you can read up on http://ftazeta.com/viewsat-platinum-extreme/
Username: Mrgreg
Post Number: 1495
What no response Fish?
Username: Mrgreg
Post Number: 1496
Still Waiting
Username: Mememememe
Post Number: 152
Post Number: 337
Need to Register?
Forgot Password?
Enable HTML code in message
