Vizio VA220E
Username: Radigan
Hi everyone,
I am in the process of fixing a Vizio VA220E and I am stuck, I cannot find a schematic so I'm doing my best without it, on the main board I have removed a heat sink and for a chip I believe to be bad but I can also find nothing about it online, it is a MT5380LTU. The issue I am getting with the TV is when it comes on it is just blue and it does not allow me to go to any inputs. When I try to switch to an Input the screen jumps a little and then it goes black and returns to blue after a moment. If I try to bring up the menu it returns a slightly off blue to the screen where the menu should be. I really hope someone can give me more information about this.
Thnak you everyone who helps out.
Need to Register?
Forgot Password?
Enable HTML code in message
