Samsung HLP6163WX/XAA TV No Connection
Username: Mcfrank35
Indiana United States
I have a samsung model HLP6163WX/XAA. but i seem to have a settings problem. i have all the connections in the right areas but i think my setting off can anyone help
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 884
Samsung do not show a source device in the input menu unless it is turned on. If it is turned on it could be a set up problem if you are using HDMI. Try composite RCA cables, Yellow Red White, see if you get a connection and do a set up.
Need to Register?
Forgot Password?
Enable HTML code in message
