Vizio vw37l
Username: Sonnieboi
i have a vizio VW37L, its a few yrs old, the tv comes on im getting sound but no picture, the screen just dark dat looks like ink all over it,. can someone help me with what you think the problem is
Username: Dtwilliamscomcastnet
Post Number: 18
Sonnieboi,
Do you have the ability to remove the back cover and do you have a multimeter to check voltages and resistance?
Your problem is likely either blown fuses, the inverter board or the backlight itself but we won't know unless we can take some measurements.
Dave
Need to Register?
Forgot Password?
Enable HTML code in message
