Panasonic 53X54J
Username: Survivor95
My 2005 Panasonic 53x54j shut off with 2 red flashes. I removed the power board (D board) from unit. Found IC451, D451, D454, D452, D456, D455, and D453 burnt. D+ diodes, Ic+ interg circiut which is on heat sink so looks like a regulator. They are located beside the convergence Sanyo chips/heat sinks. THe resistors for the stk's look grreat.What has caused this to occur? Will replacing them solve the tv not powering up? The only other thing I found was whats looks like perhaps a bit of coffee had found its way onto the 110v ac power cord attachement at the board (under the 3 attaching prongs seemed to have had coffee on them.
The tv worked good. Convergence seemed okay. It was a bit dark at angles or if you were not sitting directly in front of screen.
Anyone have a solution? Thanks.
Need to Register?
Forgot Password?
Enable HTML code in message
