Vizio 32 inch HDTV
Username: Shannon1191
I have a 32inch Vizio HDTV that I've had for about 2 years now and it's been working really good until 2 days ago it stopped working and I cant figure out why.
It will power up but then immediately shuts off. I got it to work today but the back is extremely hot. I was reading something online about it maybe being a broken cooling fan?
Does anyone think this sounds right and is this something I could fix? I called the tech support and they said it would cost me 325$ to fix! The tv only cost me 425!
Help please!
Username: Magfan
Post Number: 2294
Sounds like:: 'Welcome to the world of disposible electronics'.
IF and only IF you have a real handy friend you MAY want to try just seeing if it really IS the fan? Dust will clog them and 2 years sounds about right.
I am running my TV with fan on 'high' to help out that situation. When I turned it up, some dust came out.
Overheating is a disaster for electronics. You MAY be able to loosen it up with a good external vacuuming, concentrating on any venting?
When I get my NEW set, I'm going to sew up a dust cover and USE it when not in use.
ok thanks
I am someone who knows nothing about tvs so when you say you are running your TV with fan on high, how do I run my tv with my fan on high? I will try the vacuuming. Do you think dust buildup could cause the tv to shut off like that?
thanks for your help!
Need to Register?
Forgot Password?
Enable HTML code in message
