Unlock code for Memorex MVD2047
Username: Perkinsliu
Does anyone know the how to unlock region code for Memorex MVD2047?
Username: Noregister
Maybe like this
If you would like to adjust the region code setting on you Memorex DVD Player, simply follow
the instructions below.
1. Press the Remote Control "OPEN/CLOSE" button, to make the try open.
2. Next, press 9735 on the remote control.
3. Select your desired Region Code, by using cursor keys.
• 1 for Region 1
• 2 for Region 2
• 3 for Region 3
• 4 for Region 4
• 5 for Region 5
• 6 for Region 6
• 0 for ALL Regions
4. Press ENTER to confirm.
Then re-load the DVD disc.
Username: Darkdeath19
I have an MVD2047 as well, and I tried the above unlock code; it doesn't work, and it keeps saying "invalid key".
A fundamental question I guess is whether upconverting HDMI dvd players are capable of being unlocked?
Another question is how a regular user would go about finding this code on her own. Is it a trial and error type thing, or would there be hints in the DVD player's manual? Is it feasible to contact the manufacturer directly and request such a code?
Username: Archive
Guys, i dont know how to unlock code for DVD players, but i know a software called dvd ripping software can help you remove region code from DVD discs, and then, you can play any region dvds on your dvd players ...
Need to Register?
Forgot Password?
Enable HTML code in message
