55" proscan 1080p 240hz need help!
Username: Vida
hey, i just got this tv and it didnt have a remote or manual with it, i cant firgure out how to turn it on, there are little emblems for power and input and such on the bottom right corner but cant find any buttons on it, if it it just touch then mabe the tv doesnt work but the light at the bottom center of the tv is red when i plug it in. does anyone know how i can turn it on?
Username: Magfan
Post Number: 1277
A NEW TV without a remote?
Username: Serp
the buttons are kinda shitty. i just got the same TV, but its the slim 120hz design. if you run your finger over it, you can feel a little bump. hold a little pressure on that for a second and let go. the tv takes about 10 seconds to start up so dont push it again or u'll turn it off
Need to Register?
Forgot Password?
Enable HTML code in message
