MIT CS3515R - VERTICAL LINES
Username: Mike67stang
20 YR. OLD DIRECT VIEW UNIT. 8 MONTHS AGO WHEN FIRST TURNED ON VERTICAL LINES APPEARED ON TOP 1" OF SCREEN, LEFT AFTER 10-15 MIN OF "WARM UP". NOW LINES ARE ON 1/2 THE SCREEN AND TAKES ABOUT 40 MIN OF WARM UP. IS IT TIME TO GET A NEW SET ? WHAT DOES THIS INDICATE ? I'VE NOTICED THE OLDER SETS ARE JUST ABOUT IMPOSSIBLE TO FIND PARTS.. ANY ADVICE APPRECIATED.. MIKE
CORRECTION !. LINES ARE HORIZONTAL, NOT VERTICAL,., THEY GO ACROSS WHOLE SCREEN LEFT TO RIGHT,.,HORIZONTAL.. AND IT'S 35" DIRECT VIEW.. THANKS
Username: Plymouth
Post Number: 15585
Welcome to eCoustics MIKE!
It seem to be a capacitors leak problem in the power supply!
Check or replace the capacitors!
Need to Register?
Forgot Password?
Enable HTML code in message
