HITACHI TV CONVERGENCE
Username: Djing_2004
HITACHI MODEL # 43FDX20B REPLACE THE STK'S
STK392-150 WITH NEW STK392-120 HAD 1 BAD RISSISTOR
REPLACE THAT TOO BUT THE TV IS STILL OUT OF CONVERGENCE
DO THE 120'S WORK WITH THE 150'S OR WHAT...OR DO I HAVE TO PUT THE 150'S OR IS THERE ANOTHER RISSISTOR OUT THERE THAT I NEED TO CHECK
HELP
EDDIE
DJING_2004@YAHOO.COM
WWW.MYSPACE.COM/DJFLY11
Username: Zobeii77
Pakistan
Hi
The trouble of your tv is the convergence try to adjust it manually using your remote control. If still nothings happens the trouble is your convergence ic it is located at the back of your tv it is attached to a large aluminum plate and the ic has a marking of stk- followed by a number try to replace it.
You have defective convergence correction amplifier IC replace the STK IC...
Thanks!
Need to Register?
Forgot Password?
Enable HTML code in message
