Hi i bought a GO.Video DVD Recorder/ VCR combo (Model VR4940
Username: Zarichansky
hi i bought a GO.Video DVD Recorder/ VCR combo (Model VR4940 .
anyway i had a tape stuck in it i had to remore the tape.
a small peice broke off and then a metal part fell out.
i am trying to fix it myself but i can find no info on it anywere can you help?
i need a photo inside to put back the parts that fell out of it.
anyone please help!
Username: Jan133
if you just bought it brand new shd be under warranty and it may be faulty if tape got stuck - there is a little motor?? that lifts the tape in and out of the tape drive i think - maybe you can take back to store and explain what happened - when i first bought my sony dvd burner - the door wouldnt open to put in dvd so i took back to store - found out after they sent back to factory that the child lock had been activated at the factory - i would never have figured out that one
Need to Register?
Forgot Password?
Enable HTML code in message
