Weatherforcaster
Username: Blackman
Saint john, Nb Canada
Post Number: 11
is it down on ultra
Username: Lroy
Post Number: 533
To get WF going again, load 624 bin and update WF and you are good to go. Enjoy TV with WF.....
Username: Breezelow
Buda, Texas USA
MAXHD is down as of yesterday. Charlie up to his old tricks with an ECM. I've read that all the VS weather forecasters are totally down. Will need a new o/s higher than 616 to get channels back.
Username: Lroy
Post Number: 535
breezelow, just follow the instructions in the above thread. VS + WF is working great on 624 bin......
Username: Breezelow
Buda, Texas USA
Post Number: 9
Thanks for the advice lroy, but 624 "bin" is not for the VS MAXHD. Many others reporting all other VS's are down. I've been searching several other sites and that what I'm getting. What mod. rec. are you using?
Username: Lroy
Post Number: 536
Breezeblow this is the 624 for the HDMAX
http://www.ftacp.com/PFTAHDMSW-100624HM.zip
Username: Breezelow
Buda, Texas USA
Post Number: 10
lroy, I did find a 624 for the vs maxhd, tried it and it don't work at all either. Looks like will have to wait for new file after the 624 from VS.
Username: Lroy
Post Number: 537
Did you update WF after loading 624..
Username: Nydas
Post Number: 19253
If having trouble, do 616, 624 and then update WF
Username: Breezelow
Buda, Texas USA
Post Number: 11
Yeah, did all the procedures, exactly as recomended by many other sites too and nothing. Seems other rec. are working just not the VS MAXHD looking at 119 and 110. I don't care to try for bev programming. Will have to wait on new PEG file from VS. Thanks for the suggestions though.
Username: Breezelow
Texas USA
Post Number: 14
leroy tipit and/or nydas. I have stopped trying for a working VS MAXHD pointed at 110 and 119 (dn only) with any of PEG files 100614, 100616 and 100624 until anyone can tell me, with these particulars, your getting normal channels at this time. (The other 3 VS rec.'s may work.) Do you?
I am convinced VS will need to release another updated working PEG file after 100624 to fix the ECM of friday.
Thanks.
Username: Lroy
Post Number: 538
YOU MAY HAVE A DEFECTIVE WF, IF THAT IS THE CASE, LOAD THE 614, UPDATE WF THEN LOAD 624 AND REMEMBER TO UPDATE WF AGAIN, AND YOU SHOULD BE WATCHING TV. TRY THAT AND GIVE A FEEDBACK. I PREVIOUSLY HAD A PROBLEM WITH WF AND THAT WAS HOW SAME WAS FIXED.
http://www.satfix.net/attachment.php?attachmentid=4542&d=1276717045
http://www.satfix.net/attachment.php?attachmentid=4648&d=1277373210
Username: Nydas
Post Number: 19265
My general impression is that a lot of people have had and are having trouble with 624 and VS MAXHD. However, by patiently working in a precise sequence of loads (see post above) most seem to have got going.
Username: Spank
Post Number: 351
There is a new file (6/27) for the weatherforcaster. Try that one.
Username: Sat22
Post Number: 38
Hi guys,
I'm interested in the VS WF for my Ultra. I'd like to get some feedback from those of you who have been using it. How reliable, downtime, freezing, ECM, etc..Also are both Bev & DN open except PPV ?
Username: Lroy
Post Number: 541
Ultra + WF running good on DN and B3V with 627 bin. No freezing.
Username: Breezelow
Texas USA
Post Number: 23
I finally got mine working roy. Thanks for all the contributions at this thread. Lots of great suggestions. It was really tricky. Anyone else still having trouble check out my "now working" thread.
Username: Tasmanian_satellite
Post Number: 109
will WF work on viewsat lite and will it work today should i purchase one.thanks
