Hi to all, I have 110,118,and 119 with dish 500 plus sw34,and all are working good and I like to get bev 91 0r 82, FYI there is 18" dish that I have do I need anather sw,Thanks
You will probably need a 4 x 4 switch. 3 x 4 switch is good for up to three LNBs, which in your case currently are good enout - 118/119 on one input port and 110 in another input port. If you add 82W and 91W, you will need two more input ports, which you will get from 4 x 4 switch.
here is how i have hooked up mine i have dn on one switch and b@v on another with 2 cables coming to the receiver, so i just switch cables this is probably the easiest and cheapest way of setting up 5 satellites if you want to set up like this, then yes you will need another switch for b@v, just get a chieta heavy duty
