LG V181
Username: Hotdog59
Hello I'm John.
I have, believe it or not, 3 LG V181 DVD Video cassette players all of which have the same problem.
When a video cassette is inserted, the cassette becomes stuck and any attempt to remove it using buttons etc is pointless.
When i try to remove the cassette the tape is jammed within the mechanism, thus destroying the cassette.
Am i doing something wrong? I assumed so since it was happening to three machines.
Any suggestions as to what if anything can be done to address this problem would be greatly appreciated.
Cheers
John S
Username: Hotdog59
I note that on previous forums that codes are referred to as a common issue.
I have no idea what is meant by theses codes or whether they are relevant to my issue or not.
All three of my units did function well for quite some time prior to the tape jamming issue.
Hope that this added info helps.
Please help.
John
Need to Register?
Forgot Password?
Enable HTML code in message
