Toshiba dvd video recorder dr430ku
Username: Kevin39
Hi
i am thinking on buying a Toshiba dvd player recorder.this is a toshiba model dr430ku in bestbuy for $119.99 it one of the new its ones toshiba has out. i did a google search but can not find any reviews on it. is this a good deal?
thank you
Username: Ieee488
Post Number: 326
It is tunerless so you'll need a cable box.
Most DVD recorders work fine at recording 2 hours to a DVD.
Username: Samijubal
Post Number: 4233
It's a Funai, same as Philips, Magnavox, Sylvania, SV and half the other recorders out there.
Username: Guardstarr15
I just bought a Toshiba DR430KU and i cant figure out how to record a television program, can someone possibly help me with this problem?
Need to Register?
Forgot Password?
Enable HTML code in message
