Samsung HL61a650C1F Cycles on and off
Username: Bitbucket
When I power up the TV, Lamp led flashes, ballast lights and makes loud buzzing noise for about a second then light goes out for about a second, then comes back on and does the same thing, then lamp lights and I get tv for about 15 or 20 seconds, then relay clicks and tv powers to standby and starts the same process over again. Anyone experienced these symptoms. Any input appreciated. Thanks.}
Need to Register?
Forgot Password?
Enable HTML code in message
