Insignia IS-dvd1001 DVD recorder
Username: Nayls57
Crawfordsville, Indiana United States
My recorder all of a sudden has quit reconizinging my pre-recorded DVD's and will not recognize any of my blanks to initialize.
Is there some way of doing a reset on this machine? It has been a great recorder, and this just did start happining, i have tried over 6 different brands of blanks, and the ones they recommend. it says unfamiler disk, please check disk. and pops it out. plese help thanx!!
Username: Samijubal
Post Number: 4123
I'd try opening it and cleaning the lens. You've probably got a bad burner. Standalone burners don't last very long. Some LG recorders use a PC type burner that can be easily replaced.
Need to Register?
Forgot Password?
Enable HTML code in message
