Multiple DVI Devices?
dale
This may be a stupid question but it's something I just keep coming back to while trying to piece together a home theater system.
What's the general practice for attaching a DVI DVD player and a DVI satellite receiver to a HDTV with a single DVI connector? Do people just forgo the DVI connection on the DVD player and use a component connection? Or is there a switch box type thing you can buy?
You can buy a remote controlled DVI switcher that will cost about $200.
Derek
Dale, that's what I would do. But if you want a switch, see:
http://www.pacificcable.com/DVI_Switch.html
or
http://www.ramelectronics.net/html/hd-DVI-2x1.htm.
John G
The DVI Switch box for HDTV is also available at www.gefen.com and can be purchased with a remote control.
