Different Channels with different TVs
Username: Khadorcaptain
My previous HDTV, a Westinghouse, picked the OTA HD channels as well as everything else provided by my cable provider through an analog cable connection, plugging straight into the TV. I upgraded to a Sony, and now I no longer receive the OTA HD channels. Nothing has changed other than the TVs. What gives?
Username: Tapeman
New York City in-HD, NY
Post Number: 2230
- Did yo scan all digital channels correctly?
Some TVs maybe tricky than others
Username: Justinemalius
Rockville, Md Us
I am having similar problems. Our new Sony KDL-46W4100 doesn't find all of the unscrambled digital/HD subchannels carried by Comcast that our much less sophisticated and much cheaper Trutech does [e.g., the Sony can't find the 3 digital/HD channels that local ABC channel 7 broadcasts - 7.1, 7.2 and 7.3 on the Trutech]. And the signals it does find don't have the same channel numbers on the Sony as on the Trutech [e.g., the HD boadcast from local PBS channel 26 is tuned in as 26.1 on the Trutech versus 103.11 on the Sony]. Both have QAM tuners and are connected directly to Comcast digital cable without going through a box. When I talked to Sony customer service about it, they made it sound like they never heard of this before and suggested that maybe the cable signal strength was weak.
Need to Register?
Forgot Password?
Enable HTML code in message
