Connecting Sony CD/DVD player and cable box
Username: Bob331
I have a HD TV hooked up to a Time Warner cable box . I was just given a (used) Sony CD/DVD Player. The Sony manual does not contain any instructions as to how to connect the player when you have a cable box.
Help, please ?
thank you.
Bob
Username: Ieee488
Post Number: 618
What does a cable box have to do with anything?
You connect up the Sony directly to the TV.
Username: Bob331
That seems easy !
I was recalling when I had to hook up my VCR - it went through the cable box. So the DVD is different.
Thanks.
Bob
Username: Ieee488
Post Number: 619
The VCR had to go be connected to the cable box only if you wanted to record TV programs. It could have been connected directly to the TV if you merely wanted to watch tapes.
Username: Bob331
Of course !! Makes perfectly good sense. Duh !
Bob
Need to Register?
Forgot Password?
Enable HTML code in message
