Nalin
Username: Kirankumar
NO Bashing
Post Number: 2272
can a zinwell multi switch be used for fta
Username: Nydas
Post Number: 9713
I have seen it recommended in FTA forums. I will try and research this more tomorrow.
Username: Mucho
Post Number: 163
YES
C/P
This switch allows you to to combine signal from two satellites and install it on up to 4 satellite receiver. Need to go to 6 receiver? Buy a 3X4 switch and this 4x3 switch. Then you can "piggy back" them. see diagram below!
2 satellites to 4 receivers
(4X4 Switch Diagram)
Username: Lklives
Post Number: 15034
zinwell is just a company name...and multiswitches are commonly used in FTA..which one U use with which FTA receiver will determine its compatability..
Username: North_of_ontario
Post Number: 608
NO Bashing
Post Number: 2273
thanks guys
i will try it out and post results
