Does Philips 29pt902 support PAL 60?
Username: Metmet
I have a Philips 29pt9020 TV set. Does it support PAL 60? All newer CRT TV sets are supposed to. But when I try setting the display mode on the MC XBOX 360 to PAL 60 the picture goes out. And some of the games (DOA 4) work only in PAL 60 mode. So do I have to buy a better TV or is the problem in the settings or smth? Thx for the answer!
Username: 18petras
Same problem for me. Have you found a way to figure out it?
Username: Metmet
No, sadly i didn't
I sold the TV and bought a Samsung LCD
Need to Register?
Forgot Password?
Enable HTML code in message
