My HDTV not displaying High Definition for my XBox!
Username: Gregquinn
I've just gone out and bought an XBox 360 premium. I have plugged it in and selected the HDTV option switch on the cable. However when I try to change the settings to 720p or 1080i, my screen just goes blank and then returns back to the default 480.
My TV is a Samsung 42" Rear Projection that is "1080i Ready". So why does it go blank when I change the setting?
Help, this is very frustrating!
Thanks
Username: Angie8220
we are having the same problem with the samung and xbox 360 except know the tv dosent work
Username: Gregquinn
Hi Angela,
It looks like the problem was the Samsung TV could display 1080i and 720p, but only at a refresh rate of 50hz. The Xbox outputs to those resolutions at 60hz, thus the TV can't display it. Only thing you can do is try doing all the updates for the Xbox and hope something there gives you more options.
Username: Donnie1973
Post Number: 1843
i think u have to set it up in the control panel of the xbox
Username: Mrbass
Long beach, California United state
Post Number: 147
ya because your not using component nor hdmi,
Username: Dylanger
Post Number: 9
check your settings on your xbox cp i had this problem until i changed my settings.
Need to Register?
Forgot Password?
Enable HTML code in message
