S-Video input dead on Sony KV-24FV10
Username: Zork_99
GTA
Post Number: 31
The S-Video input no longer works on my Sony KV-24FV10 on Video 1. I have verified that it is not a source problem(tried Satellite box and Cable box) and have also ruled out the S-Video wire by trying another wire that i know works. The Composite Video Input and the sound Inputs for Video 1 still work, but only the S-Video input is dead....Anyone have any idea as to what the problem would be and is it really worthwile to fix such a problem?
Any help would be much appreciated..Thanks in advance!
Username: Tapeman
Post Number: 672
It happens all the time due to either:
- Broken pin inside S-VHS fitting of TV set
- Broken pin on PC board
- Loose ground or part of circuit
- Damaged pre-amp
What you may want to do:
- I will still try another S-VHS cable
- Try different video input
- Try same input but use RGB component input
- Use yellow single video in instead of S-VHS
- If you got hands on electronics open it and repair it
I know you maybe concerend about quality but you may want to just get by instead of paying $200 for simple problem
Need to Register?
Forgot Password?
Enable HTML code in message
