Need service menu code for Mitsubishi CK35FX2
Username: Cxturbo
I'd like to do some tweaking to my Mitsubishi CK35FX2 but cannot find a code that works. The codes I'm finding on the net seem to be for newer models. I know for a fact that it does have a service menu because it shows it in the owners manual with directions on how exit it in case it's "accidently" accessed.
Anybody have this code? My guess is any Mitzu from the early to mid 90's would have the same code.
Thanks,
George
Username: Stevestar99
Dahlonega, GA
Post Number: 83
Mitsubishi seems to have a variety of access codes depending on model and manufacture date. Some of the codes are:
Press:
[MENU], then [1], [2], [5], [7]
[MENU], then [1], [2], [5], [9]
-or-
[MENU], then [1], [3], [7], [0]
-or-
[MENU], then [2], [3], [5], [6]
[MENU], then [2], [3], [5], [7]
[MENU], then [2], [3], [5], [8]
[MENU], then [2], [3], [5], [9]
-or-
[MENU], then [8], [2], [5], [7]
Then use VIDEO or AUDIO buttons to enter two different groups of adjustments. Video/Audio steps along through the adjustments, and +/- does the adjusting.
Must use [ENTER] to save the change.
Hit the [MENU] key twice to exit service mode.
If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
You may be able to find additional information at Bob Page's Mitsubishi TV Service Modes web page.
Need to Register?
Forgot Password?
Enable HTML code in message
