Tuning Hitachi C14 P218 CTV
Username: Chevvy
Does anyone know how to retune channels on the above TV please.
did you ever find an answer as i have same problem
Username: Chevvy
No, I never did receive an answer. The TV is just sitting there with no remote and untuneable.
Ian
Not sure if it's the same sort of set-up as the C1415T & C1714TE, for which I have a manual. But the directions for those are as follows:
1) Hold down the 'MENU' button until programme index appears
2) Press 'MENU' once more, use the left and right arrow keys to choose the channel then arrown down to tune. Repeat for the fine tuning (although the one they chose was always the best for me). Then arrow down to 'STORE' and press right till it says 'STORED'.
Hope this helps... Rena and Rob
IrishWomble
You need a remote (CLE-876A). Press the preset button, then using the volume controls on the TV, manually tune it in.
My problem is getting a DVD and/or Digital Setup Box tuned in. No AV mode, and it doesn't seem to pick up the signal when re-tuning.
chezza 28
its f***ing annoying is this tv!!!!!!!!!!!!!!!!!!!
It's picture control and then fine-tuning
chezza 28
Need to Register?
Forgot Password?
Enable HTML code in message
