Pick out my tv to buy!!!
Username: Lowfront
Post Number: 48
Alright I need some suggestions as to what to buy. My viewing is close like 4 feet away....
Username: Dmwiley
Post Number: 836
Budget?
Username: Lowfront
Post Number: 49
Idk...Mabe around 300-400 whatever worth it
Username: Dmwiley
Post Number: 847
HD not in that budget. Check Sony, Panasonic, Sanyo and Sylvania. Buy the one that has the best picture and feature set that you need. Check Consumer Reports for recommendations.
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 8
David: at 300-400 you wil not get HD and at 4 feet away you need HD or you will see alot of snow and movement in the picture. Buy a 4:3 standard TV that is HD ready it will cost more like 600-700
