Problem with analog audio inputs
pg823
All of the analog adio inputs on my Pioneer VSX-36TX do not work. The red "over" (meaning overload" icon appears whenever an audio analog input is selected. All digital audio inputs work fine. There is a feature with decreases the strength of the analog signal but after doing this, the problem persists. The tuner tunes to local FM stations but all I hear is noise.
sorley
Disconnect all analog cables going to the receiver. Maybe one of them is hosing your system. If your red "over" is extinquished, try plugging in your sources one at a time to find where the problem is.
