Bose CineMate ll analog input
Username: Olaro
Hi!
I have recently bought an used CineMate ll. The problem about it is that when connected trough optical wire works fine but if I try connect it trough analog wires, then only one channel works and the sub. Does anyone has any solution to get sound from both speakers? Can it be from settings? If not can the module be fixed (considering that the fault is at the interface module) or do I have to buy a new one?
Thanks!
Need to Register?
Forgot Password?
Enable HTML code in message
