CD Player Will Not Work
Username: Mdresident
I have an Emerson Cassette / AM-FM Radio / CD Player Model PD6517BL and I keep getting an error message "dn" when I am trying to play a CD.
Username: Magfan
Post Number: 2234
If the cassette section is not a 'must have', and a simple cleaning of the laser in the CD section doesn't fix it, you should probably find a willing landfill or electronics recycler.
I don't know what the 'dn' error code means......
Do you keep any music on your computer? I-tunes or any of a bunch of other programs, many free, will allow you to put your CDs on the computer and either go the Ipod / Dock way or more elaborate 'music server' route.
The 'pod method will easily exceed cassette fidelity and the 'pod is very portable and will stay with you anywhere.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 4709
Are you sure it's "dn" and not "nd"? I'm guessing it means "no disc". It can't read.... toss it.
Username: Magfan
Post Number: 2235
'dn' is Disk? No?
'nd' is of course, as you say, 'no disk'
the 'dn' code is the machine just being polite.
Username: Dmitchell
Post Number: 4712
LOL.. well, if it's polite, you may just want to keep it around.
Username: Jan_b_vigne
Dallas, TX
Post Number: 16065
Certainly! There isn't enough politeness around.
Just don't get jealous if it starts hanging around with the vacuum cleaner.
Username: Magfan
Post Number: 2241
Or trying to mate with Jan's atari.
Username: Dakulis
Spokane, Washington United States
Post Number: 1276
Why do you think there's a hole in that disk. The Atari is entitled to some fun now.
Need to Register?
Forgot Password?
Enable HTML code in message
