Sub x over vs A/V x over
Username: Diggytooth8
Post Number: 10
Morning,
When I choose "small" for my mains my A / V receiver forces me to choose a Xover setting, I would rather use the built in one on my sub. Having said that, I assume that when I choose say 80 hz on the A / V then I should set the sub x-over at what? I suppose I should set it all the way up, to the highest setting?
Thanks all.
Username: Nuck
Post Number: 15415
Choose the lowest setting for your sub, then adjust the sub frequency response up from there.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 4281
What I do is set my front speakers to run "full", then adjust the x-over setting on the sub to lowest frequency of your fronts, or as close as possible.
Need to Register?
Forgot Password?
Enable HTML code in message
