Klipsch VF-35 integrated match
Username: Split_shoes
I bought a pair on Klipsch VF-35 floorstanding tower speakers and I am looking to purchase an integrated amp since I have been pointed in this direction because I am only using the set up for music - CDs and ipod(no radio), not for movies or TV. This is a bedroom set up.
My budget is about $500. The only integrated amp I have been able to find in store is the NAD c315bee, so I do not know much about anything else.
Any suggestions?
Thank you.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3784
You could drive those speakers with pretty much any amp, even a 15 watt T-amp.
Username: Nuck
Post Number: 14866
The little BEE might be a fun setup, given that it does not have the same bass 'bloom' that IMO I associate with larger NAD offerings.
The power will be sufficient, and NAD offer several cdp's, new and used, that have a good feel with NAD amps.
Username: Dmitchell
Post Number: 3785
... or tubes ;-)
Username: Gavdawg
Albany, New York
Post Number: 1458
I would also throw in the Pioneer Elite A-35R
It is a great little unit for the price :-) I know... I had one.
It has a smooth, rich and warm sound that is really easy on the ears. The only reason why I switched it out was that my speakers like more power. It will be a nice match for the Klipsch.
Username: Gavdawg
Albany, New York
Post Number: 1543
Good point david...
Username: Dmitchell
Post Number: 4187
So what did you end up getting LF?
Need to Register?
Forgot Password?
Enable HTML code in message
