Amp wiring - Ya ya not subwoofer related
Username: Skateguy92
Post Number: 116
I finally have my whole setup coming together and I think I am over-thinking the wiring aspect.
I actually got ahold of an old school US built eclipse amp to power my front stage (CDT HD-62's).
It is a 4 channel 60x4@4ohm or 120x2@4ohm bridged... I figured I would use the bridged channels.
How exactly do I wire up the components to get a 4ohm load? or should I just set everything on it's own channel (do tweets/mids get the same power? assuming they do since they are normally hooked up together)
If anybody is curious the setups is....
JL HD750/1 powering a 13 w5
Eclipse 120x2@4
HD 62 CF - with the ACTV crossover
A bunch of Second Skin Damp Pro to put on the doors.
Oh and a Pioneer 3200bt for the source.
Username: Nuck
Post Number: 15363
bedroom door?
bathroom door?
Maybe the car audio forum will find an answer, Austin.
Need to Register?
Forgot Password?
Enable HTML code in message
