Insaneium in the crainium?
Username: Maximum_boost
Columbia Heights, MN USA
Post Number: 7
If my receiver has a left & right sub channel w/ a + and a negative output I would be able two hook it up to a dual voice coil sub right? But if my sub outputs combined bump out a total of 150 watts, a sub that can handle only a 40 watt RMS and a Instantaneous peak power wattage of 200 won't cut it will it?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3802
What kind of receiver is this?
Need to Register?
Forgot Password?
Enable HTML code in message
