Groove-y
Username: Ezntn
Greeneville, TN
Post Number: 170
Imagine the time we spend with that high dollar stylus going round and round in this thing
/http://www.boingboing.net/2010/03/16/vinyl-record-groove.html
Username: Artk
Albany, Oregon USA
Post Number: 12360
Works for me!
Username: My_rantz
Gold CoastAustralia
Post Number: 3058
Yeah, but you gotta wonder why!
No wonder those things make a noise.
Username: Artk
Albany, Oregon USA
Post Number: 12381
Beautiful noise !
Username: My_rantz
Gold CoastAustralia
Post Number: 3081
The picture makes me wonder if vinyl would sound better if you lubricate the groove with oil!
Username: Magfan
Post Number: 980
Yes you can....and at the same time ruins your cart.
I used Armor All as a desperate / last measure once and all surface noise disappeared. The cart at that point simply could not be kept clean for even one side of the disc.
Petrol based oil may act as a solvent? It may also be possible to *build some lubricity INTO* the vinyl at compounding. Any lube would have to be able to take whatever temp was needed to liquify for pressing. Silicon oil might work....or simply gum up the works. Over in the thread on phono preamps, Jan indicated that silicon oil has fallen out of favor for cue arm use.
In the pic at the start of the thread, is that a NEW disk or has it been spun and if so about how many times......
Username: Ezntn
Greeneville, TN
Post Number: 174
Of course its new.
If it was old and well played, you could see the grooves from the other side
Username: Magfan
Post Number: 983
Good SEM work.
Is there a top view available?
How about a compar-o with a well played disc?
Username: Nuck
Post Number: 14795
Hey there's my car keys!
Need to Register?
Forgot Password?
Enable HTML code in message
