NAD 355 or MARANTZ PM7200? PLS help!
Username: Frank_ding
Hi Gentlemen, I have owned a pair of wharfedale EVO 2-30, the sound is nice!
My current Amp is MARANTZ PM7200, CD player is MARANTZ CD5003, and my favorite music is classical music.
The dealer suggested me that I should upgrade the Amp to NAD 355, it is more powerful & can control the bass better, it is more suitbale for playing symphony.
Please help me to make a decision! Thank you!
Username: My_rantz
Australia
Post Number: 2291
Ask your dealer if you can give it an audition in your home - otherwise 'heads Marantz, tails NAD'
Hi M.R. thank you very much for your advice, that's exact way which I am planning to do, but I am not so sure if my dealer would agree that, I will try!
Username: My_rantz
Australia
Post Number: 2292
hearing a component with your own set-up and surroundings is obviously the optimum way to see if it is going to be a fit. Not always possible. I pay my dealer for the component, take it home for a day or two and either take it back for a refund or keep it.
More power is always preferable, but more watts doesn't give much more power unless it's a huge amount of watts difference. Performance counts.
Dear Mr. M.R, I apprecaited your very good advices!
I just talk with my dealer, she agreed that I may take the NAD 355 bee home with free and make a try. If I am satisfied, then I buy, otherwise, just return it back.
The price of NAD 355 in my place is much higher than MARANTZ PM7200. Say $800, Double price than PM7200.
Need to Register?
Forgot Password?
Enable HTML code in message
