Classe CP-35 or DR5
Username: Snapcat
Post Number: 74
Any thoughts on either of these with a Rotel 1080 amp in balanced set up to drive B&W (600's) or PSB (Image) bookshelf speakers?
Username: Nuck
Post Number: 11025
The DR5 is a very good pre, especially the phono. It has no remote.
The cp35 usually has no phono, and if it does it is not very good. Has remote.
The cp 35 has a FL display that has been known to cause problems(I just fixed mine), but works flawlessly regardless.
The DR5 has a bias adjustment, so matching to another amp is a bit better.
Both are balanced, extremely quiet and musical, with the cp35 being a touch more dry than the fuller DR5.
Username: Nuck
Post Number: 11026
Both are at the minimal end of their respective series', thus the lower $.
Username: Snapcat
Post Number: 76
Thanks Nuck, just what I needed.
Don't need the phono.
Real reasonable $ on A'gon. Looks like a great option for a balanced pre at reasonable price.
Username: Nuck
Post Number: 11028
I believe so, yes, snapcat.
Mine is a cp50 from the same line, very similar.
Username: Nickelbut10
Post Number: 2042
Classe Rocks. I am going to try some of their stuff out soon. Or come to Nucks house to hear it. BOING!!!
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 1661
I gotta buy something new soon, so I get the "BOING!".
Need to Register?
Forgot Password?
Enable HTML code in message
