The right channel from my cassette deck in my car is extremely quiet.
Username: Iruk112
I have a 2004 Toyota Highlander. I use my cassette deck as an interface for my iPod. I have narrowed down the issue to the cassette deck.
How can I fix this? (demag, clean, or is it hopeless?)
Username: Jan_b_vigne
Dallas, TX
Post Number: 14827
The problem only exists when you play tapes or it exists whenever you use the player for any source?
Username: Iruk112
Only with tapes, everything else works just fine. Therefore I dont believe the speaker is at fault.
Dallas, TX
Post Number: 14831
Could be several different things but the most obvious in a car system is head alignment. About the only thing you can fix yourself, however, is cleaning.
Username: Superjazzyjames
Post Number: 2006
Need to Register?
Forgot Password?
Enable HTML code in message
